hood struts
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
hood struts
I have an 82 camaro with a factory fiberglass hood and I need to replace the hood struts. Are they special tension ones for that year and hood or would all 82-92 hood struts work?
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You have to get fiberglass struts so they won't crack the hood. The steel struts are way too strong.
Here are the part numbers that I'm using:
GM - 14045326
GM - 14045326
