4th gen seatbelt guide Q's Help :D
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Ok just got a set of 99 T/A leather seats for my 89 and I'am wondering how do i go about looping through the seatbelt guides cause there is no slit in them so do I unbolt the top or bottom of the seatbelts to get this thing through.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I just cut my own slit and it works great. I assume you can feed it through if you took the seat belt aparts some how though.
Kevin
Kevin
Engine: L98 350 TPI
Originally Posted by scooter
I cut a slit in the guide in between the 2 screw holes so it isnt that noticable and so it doesnt lose much strength
Kevin
Car: 89 GTA
Yeah i was kind of thinking the same but if it's not to bad to take apart the seatbelts I rather do that if I can.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I may be wrong but I dont think you will be able to take the retaractors apart, or get the belt off the retractor. I think it is swen together at the end so there is no possibility of it coming apart in an accident. Again I may be wrong but if you find out if you can or not let us know. If I ever do it again and they can come off I may take the time to do that
