Ground effects for 1987 T/A
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
Hey guys,
I am looking for the rocker panel ground effects for my 1987 T/A. I went to a local hot-rod shop here and they ordered some in from Classic Industries. They got me part #PT1552 ,which is the only one listed. These are not the right ones however, they fit flush with door and body, mine go right to the seam where the seal of the door goes and also underneath a bit to, kinda like a "U" shape. Does anybody know a supplier and part numer for these ground effects.
Car: 1987 Transam
Come on, someone out there has gotta know. I would use search, but as you know it has been disabled, so any help would useful.
Car: 1987 Transam
Sorry to bring this post back up again but I still haven't found an answer and I am going back to the shop again today and don't want to leave empty handed. I have tried searching on Google, but with some many hits it is like finding a needle in a haystack, so if someone can just let me know it would be much appreciated.
Car: 1987 GTA
Transmission: 4L60e
maybe if you posted a couple pictures of the ground effects you have and the one you got from CI someone could help out. Your description is good...but not good enough.
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Not trying to insult your intelligence, just wanna make sure here, but did you make sure that part number was the right one for your car? Did they possibly get the wrong part in? Even if it was ordered correctly, maybe they just shipped the wrong one...its happened. Just thought Id ask.
Car: 1987 Transam
Well I didn't get in to the shop today, worked some OT instead. But I did take some picture. I checked the part against the one on CIs website and it looks similar, and its got a tag on it that says 82-92, so I have to assume it is correct. Anyways here is a picture of what I got, notice how they are pretty narrow (there is 2 taped together there)
Car: 1987 Transam
And this is what I have, notice how they come off the door a bit, and of course they go under a bit but I didn't want to take a picture of the bottom. I have been looking on CIs website and it almost looks like the ones I need are from a Camaro, but these are factory installed and I highly doubt they would do that. Hope this helps.
Car: 1987 Transam
Thanks deadbird. I looked at the drawing and it looks like I need #4, it appears CI doesn't sell a direct replacement for it, just a general one. Now one quick question, I am assuming that it gives the GM Part# but how do I enter it in GM Parts direct website, it seems I have tried every combonation of the numbers 0410035785 or 5786 and I can't seem to get it right, I know I am pretty bad with computers but this is driving me crazy.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
0410035785
That's actually 0.4 10035785.
0.4 is body shop estimated time in hours for R&R.
10035785 is the OEM GM part number you need to enter.
Car: 89 IROC t-tops
Engine: 5.7 (350 tpi)
Transmission: Auto (700R4)
Axle/Gears: 9 bolt disc with 3.73's
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Theres only a few ground effects that came on 3rd gens and for the 87 you should have this kind:
Sounds like the shop sent you these
These are the 91-92 which you SHOULDNT have on an 87
These sets have to be a matching rocker/door set and do not interchange (visible differences)
Hotrodboba400
12-10-2019 07:07 PM
