power seat track removal
Old 12-26-2005 | 06:48 AM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
hey guys, im in a bit of a dilemma. im trying to part out my z28 and one of the last things left is my power seat track. i want it out! when the seat was last used it was really close to the steering wheel. so the front two nuts that anchor the track down to the body are inaccesbile because the upper track where the seat bottom is anchored is in the way. i cant just use the switch since the car pretty much stripped. so how do i go about this? is there anyway i can manually move the track back or somehow jump it to move it back? . if you really need pics let me know and ill take some and post them.....thanks guys any help is aprreciated
oh and ps ill be on my way to pick up another turd gen tomorrow.
Old 12-26-2005 | 01:24 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The power connector for the seat is underneath the seat,on my '83 it's and 2 wire orange/white connector.You could tap into that with 12 volt power supply or a battery to move the seat.Or if you wire harness is still intact,including your batter cables,you could set a battery in for power.
Old 12-26-2005 | 02:05 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You can't even get to it with a box wrench? I can't recall how much room is under there with power tracks, but the manual leaves plenty of room.
Old 12-26-2005 | 02:20 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I had a power seat that was out of a car but the thing blocked the bolts. So I just tapped the wires into a battery and moved it back.
Old 12-26-2005 | 03:53 PM
alright cool, ill look for that. thanks!!
jaridjohn
07-08-2024 04:49 PM
Vintageracer
01-10-2020 06:33 PM
Azrael91966669
25
06-20-2017 05:04 AM
86White_T/A305
08-17-2015 01:16 AM
3rdgenparts
08-08-2015 08:09 PM
Quick Reply: power seat track removal
