IROC Wheels
Old 12-26-2005 | 04:18 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
IROC Wheels
Can I put 88 IROC wheels on my 88 that came with 15" wheels? I know it will throw off the speedometer a little bit but otherwise do I need spacers or will I have other problems? I appreciate the advice.
Old 12-26-2005 | 04:38 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Yes. No spacers needed.
If you install them with 245/50/16 tires they shouldn't throw off the speedometer.
Old 12-26-2005 | 05:17 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
yea ditch thoese 15's and put the irocs on
Old 12-26-2005 | 09:09 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Original tires would have been 215x65 series that were about the same diameter as the 245x50 on the IROCs. For a better ride and still good looks you can go with a 225x60 and still have a pretty close speedometer.
Old 12-27-2005 | 01:46 AM
JoshDT91's Avatar
Engine: 2.8L V6
From what I have seen through various calculators the speedometer would not be off by a lot. Just not sure if I want to make the purchase or not. I was thinking with the larger wheels I could also get rid of my whimpy one piston front calipers. One problem, it all costs $$$$.
Old 12-29-2005 | 01:15 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
ive got a set of wheels from an 88 iroc with or without tires if your interested throw me an offer.
Old 12-29-2005 | 01:58 AM
Gr89RS's Avatar
Car: '02 Z06
Actually with a 225/60 you would be running a 1" taller tire than if you went with the 245/50. Doesn't look to good at all to me. The speedo would be off by about 4% too slow.
BlueIroc-Z
06-09-2019 04:22 AM
kah992
08-19-2015 03:55 PM
mustangman65_79
08-11-2015 04:17 PM
Fronzizzle
08-09-2015 02:15 PM
Quick Reply: IROC Wheels
