What key unlocks the T-Tops??
Car: 91 Camaro RS
Engine: 305 TBI
I have a 91 Camaro and was wondering which key unlocks the T-Tops and how do you take them off?
thanks for helping a newbie,
fisherman
fisherman
Car: 86 Camaro IROC-Z
Engine: 305 LB9
It should be the same key that unlocks the doors and hatch, if the cylinders werent replaced with a different key combo. And then you just pull on the lever towards the inside of the car and then lift them off.
1 Post
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
if you're asking because you cant get your key to work...
they're probably swapped out tops from another car.
Thirdgen89GTA
11-26-2015 11:04 PM
