Notchbacks
#51
#52
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I sometimes like that ZR1 light assembly, refering to the top in the pic. But problem as I see it is one would have to change the front headlights a bit. The driving lights already match, because they're not perfectly square or sharp angles, they're a tiny tiny bit rounded, oval shape.
#54
Car: 1986 z28
Engine: 350 block.11.0 to 1 comp .638 cam
Transmission: 700r with a 3800stall,shift kit ect
Axle/Gears: 4.10posi 10 bolt
Re: Notchbacks
i kno this an old thread,but i have had two notch backs.one oem and the other was alil bit diff.it didn t have the rib in the center, the problem is i have a gap between the hatch seal and the hatch. the shocks r gettin in the way.has any one else had this problem?
soulbounder
09-05-2001 10:46 AM
