Replacing door lock cylinders?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
How the heck do I get started, getting the door lock cylinders out? Is this a 'remove the door panel' approach?
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Yep.
Just remove the interior handles, winder handles [if you have them] in fact everything to get the door panel off.
Once off its pretty simple, only one connecting rod [if i remember correctly], and a horseshoe shaped clip that actually holds the door lock in.
Car: 1986 Camaro RS
Engine: 305 V8
Transmission: 700r4 automatic
I'm having the same problem. I've got my interior door panel off, trying to replace the door lock cylinders, but I can't get the clip out (I can't get a good grip that far off my door). Anyone done this before and can offer some hints/tips? The only panel I was able to remove was the interior panel, but it appears that the entire thing is one piece... thanks!
This may not help, but down a bit in the following link, you'll find a diagram that shows the set-up clearly:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
I had one hellish time with the clip, #5.
JamesC
JamesC
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I just did mine and used a long pair of needle nose pliers for the horseshoe clip.On the plastic clip retainer locks you just push the clip back with a long screwdriver.The older style it's easier to slide the clip back thru the lock cyclinder hole itself.
Also do you have new weather seals for your lock cylinders?It's also a good time to take a good look at what shape the exterior door handles are in.
Car: 1986 Camaro RS
Engine: 305 V8
Yeah, I've seen how narrow the space is... And I was afraid of that.
I'll try a flathead screwdriver to get the clip out. The rest of it seems to come out pretty easily. I'll also get the seals for the locks, as they're probably ready to go too.
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Those c-clips get corroded and then they are hard to pull out. Try soaking it in wd-40 or something similar. It will be messy, but they will come out. Make sure they are nice and clean before you put them back in. Good luck
Car: 1986 sc camaro
Engine: 489 bbc
Re: Replacing door lock cylinders?
I was wondering if anyone knows of a lock set that uses the same key for the doors ignition and trunk lock ? ecklers has 33-190028 witch is a repo and has ign and doors on same key but no trunk
1992 Trans Am
05-10-2023 07:19 PM
Zachattack0925
08-12-2015 09:52 PM
