Hatch won't open!
Old 11-27-2005 | 10:18 PM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
Hatch won't open!
Is there any way to open the hatch in my '85 T/A, the key hole is messed up and I think the hatch motor or release is disconnected.
Old 11-27-2005 | 10:26 PM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
Do you own a hammer, a chisel, and a long screwdriver?
Old 11-28-2005 | 01:51 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
...........oooorrr.....you could just pop the light and pop the hatch manually
You might need to remove the solenoid though, then you can pop it. 10mm bolt
1989karr's Avatar
Engine: 3.4 / 5.0
Old 11-28-2005 | 06:24 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
hmm.. I have just ever used the good ole cop way of getting in.. which is to take a flathaed screw driver.. line it up with the key hole and one swift smack and the turn.. ussually works if the lock is already messed up.. since you need a new one anyhow...
Old 11-28-2005 | 06:39 AM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
How do I pop the latch manually? The taillights are in but the whole centerpiece between the taillights is out. And can I pop it from the outside? The key won't even fit in the hole and I don't see any bolts or anything?
Old 11-28-2005 | 10:09 AM
actually you know.. i think he was talking about crawling into the back of the car, popping the rear light in the well, and then popping it.. talk about a PITA route to take if that is what he meant lol
Also another great way to do it is if you have a drill.. drill the keylock out.. by what you are saying you need a new one anyhow.
Old 11-28-2005 | 03:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Yup, that's what I meant I've done it once in a JY when I couldn't reach the back cause another car was smashing the back. It's *** cause you don't really damage anything, but if the lock is already bad you might as well go with the drill way since it's gotta be replaced.
....oh and if you do it from inside, make sure the car is NOT in the sun. The hatch REALLY magnifies the sun's heat! I got an instant sunburn!
Hotrodboba400
12-10-2019 08:07 PM
2012sergen11
Interior Parts Wanted
09-07-2015 12:37 PM
TBRays98
09-06-2015 06:05 PM
luvofjah
09-03-2015 08:08 PM
Hotrodboba400
09-02-2015 08:28 PM
Quick Reply: Hatch won't open!
