Gfx
Car: 1984 Camaro Z28, 1987 Z28 (R.I.P.)
Engine: 305 H.O.
Transmission: 5 Speed
Gfx
Hi, I searched for this answer and didn't find the answer.. Is there any place that sells aftermarket/new Third gen Camaro body kits?? Or do I have to look on Ebay..
I smashed my car, and now rebuilting a new one and this is the only parts that I'm missing! It sucks!
Engine: 305 H.O.
Thx for the info man, I emailed Hawk's.. and they only has the rear quarter.. I need the passenger side, the rocker and the flair on the door is ok, it's just on the side it's cut in the middle. Same goes for the rear quarter (the wheel banged into it and bent it in half)
Does anyone know if that's fixable??
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Junk yard?!?!
If its a little section you can either use the bondo, or a bit of plastic with heat gun and patch it up. From there it should work!
Just go to Junkyard and get yourself a "new" piece, unless you have an aftermarket gfx than you have to pay (insane) amount of money for it.
Laters.
Laters.
