DIY: Sanding/polishing after spraying?
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Just a quick one regarding the steps since spraying my car. I've just finished respraying it in 2-pack PPG (3 coats) and have just noticed a few bits of dust that seem to have landed on the roof.
Its doesnt bother me greatly, but if there was a method of sanding/cutting it out i figured id give it ago. Regardless of the dust, there is also a very minor orange peel i can see and wanted to know what steps/process I should take to remove it.
Cheers
Cheers
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
wet sand and buff.
what you do is get some 3m wet sanding papaer and a sanding block 4". you put some luke warm water in a bucket and a drop or two of dish soap. the soap helps float the dust so it does not stick in the sand paper. keep the part being wet sanded wet, change your paper often as needed. wipe the area often to see if its all smooth. you must use the block to be smooth. after its all nice n smooth you need a electric or air buffer 2k+ rpm a wool pad 3m and some perfect it III polish is nice, and some finish it swirl remover for dark colors, and a foam pad for that. then you buff till nice n shiney. being very careful around edges as you can buff right through pretty quick. 2,k rpm is pleanty fast for wool pad you can go 3.5 k but be carefull, the foam pad with swirl remover run at 1.5 k nice n slow. when done you can go over with some meguires quick detailer.
jeff
jeff
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
thanks for the info. How long do you wait after painting your car? is it days weeks or months? can you get out orange peel from the clear coat or do you have to do that in the color coat? Thanks again.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Originally posted by Raven90IROC
What grade sandpaper do you recommend?
go to 1500 or 2000
then buff
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Originally posted by Token
1000 at first
go to 1500 or 2000
then buff
1000 at first
go to 1500 or 2000
then buff
Car: 1989 RS Camaro
can you get the peel out from the clear coat? I was not sure if you had to get it out before you clear coat.
Engine: 5.7
Car: 1989 RS Camaro
nice that will make my life easier. Do you know how many coats of clear I will get out of a gallon of clear, with the reduceing and hardener?
Engine: 5.7
I have the dust specs in the colour wasnt planning on putting on a clear coat, since its a solid colour.
I have 3 coats of the colour down so should have plently of room to cut back with 1200, 1500, 2000 then buffer right?
1 Post
Engine: 305 tpi LB9
umm what type of paint? single stage..... if its a base clear system you MUST put clear coat on it. Give us more info because its starting to lok like all of the above can now be ignored, those inof and tips are for base clear systems.
jeff
jeff
HoosierinWA
10-07-2015 10:15 AM
