Aftermarket Gauges for Firebirds?
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
Hey.. i am converting all the lights in my '85 bird to blue or red and i have blue bulbs in my stock dash and because of all the orange paint it is just a white light, and now i would like to buy a aftermarket guage cluster to put a end to this problem so i would like everyone to post what namebrands of gauges you are using and include pics if possable
thanks
Kyle
thanks
Kyle
Car: 1985 Firebird
someone has to know i need to know because searching isnt bringing results i need
Car: 1985 Trans Am
Axle/Gears: 3.70
There is no aftermarket gauge cluster for birds. If you want to use other gauges you'll have to go with individual gauges like Autometers. You'll have to do all the wiring yourself, as well as figure out how to mount them. It's been done, and isn't difficult. However there is no "plug n play" option.
Car: '88 IROC-Z medium orange metallic
I made one for my firebird with all autometer gauges. I got rid of the factory engine harness and all so it was easier for me to do it this way. I'll take some pics of it in the car, but for now here's these.
I used stuff called 'kydex'. Very easy to work with, but also very expensive. I just happened to have it laying around the shop at the time. I got lucky and a friend that works in construction scored a sheet for me. It usually sells for about $480/sheet You can use any kind of plastic you can get your hands on, the less brittle the better. Don't try plexiglass.
Car: 1985 Trans Am
Axle/Gears: 3.70
Originally posted by TRANSAM38387
i'm going to be doing this to my gta soon and wanted to know where you got that black plastic from. thanks
They sell all kinds of plastics and materials in all different sizes and thicknesses.
Car: '84 Trans Am
If you simply want to change the color that the gauges light up, spray over all the orange with white paint and then get colored bulbs. A company called auto instruments can reface your gauges. I'm having mine done silver with black numbers. They can also recalibrate your speedometer to 160 mph. Other than that, you would have to fabricate a custom dash panel and buy aftermarket gauges.
And props to person who did make the custom panel with the autometer gauges, that looks awsome.
Car: 87 Formula 350 / 89 Firebird
Engine: L98 / 2.8 V6
Transmission: 700r4 / 700r4
Axle/Gears: 9 Bolt 3.27 / 10 Bolt 3.42
How about just buying some new white guage faces off of Ebay?
Car: 1985 Firebird
I ended up spraying the back of the bezel a metalic blue and the amount of light it produces is very decent for the amount of work it took.
Kyle
Kyle
Ghettobird52
07-05-2024 11:18 PM
colton_carlson
03-08-2019 12:21 PM
