91-92 GFX direct bolt onto a 83 z28?
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
I'm more interested in replacing the front gfx then anything else. It is definately showing its age. The rest of the car is very clean and I am often asked if it is a later model then what it actually is. I will be painting soon and I have access to clean GFX at a local salvage yard.
So my question as I'm sure you see, will I run into any problems latching on the front GFX from a 91-92 rs onto my 83 z28? I would like to keep the stock side and rear gfx as they are flawless. Would this look strange? Any suggestions? I figure it would be cheaper then trying to repair the old plastic/fiberclass one. Plus I get the refreshing look for a smooth clean newer front.
BTW I am new and I have been searching for a forum like this for awhile. I guess I didn't search hard enough. These forums are the best source of information I have ever found on our cars. I'll definately be hanging around here.
Don't bother posting if there are older post for this info. I'll do some searching. Thanks.
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
it wouldnt look right if u just put a 92 front and kept ur 83 gfx because the 92 front gfx come lower and the side gfx of an 83 are short and stay higher up if u swap the front might as well put the 92 gfx all around trust me ull be happy u did
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Welcome to the boards. The 91-92 front gfx will not be a direct bolt on. It wont fit on the bumper. If you want the 91-92 front gfx then you will also need to replace your front bumper.
Car: 84 Z28
Engine: carb 305
