Hood (hood release) won't open
Car: 1992 RS
1992 RS - hood will not open - Hood release seems to work fine but hood will not pop - tried pushing on corners, middle etc. ANy help would be appreciated
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Have someone pull up on the hood front & center when someone else pops the release. You probably just need a little chassis lube on the latch.
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I would check the alignment of the hood, if that is ok then I would check the alignment of the hood latch/spring.
Street Lethal
04-30-2019 12:14 PM
ElPaleterro85
08-13-2015 03:49 PM
