shift knob
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
shift ****
This may be a stupid question to most of you but how do I remove the shift ****?
85 TA w/T-Handle
85 TA w/T-Handle
Car: 1991 Red Trans Am
Transmission: 5 spd manual
try doing a search for "removing shift handle" or something like that.. I found many threads...one with a diagram, but not sure if its for your exact handle..
also, if it is the one I'm thinking about with the button on the side... I'm pretty sure there is a clip on the backside of it that you have to pull out and the handle will slide off....
search would probably be your best bet though
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
pull the shifter down to first to make it easier, then just get a pair of plyers or wire cutters and look on the front part of the base of the shift **** for a little slot......use the pliers or wire cutters to grab onto the little clip, pull it out, and lift up :-P
Night rider327
02-25-2016 09:50 AM
