I Made a Shift Knob...Look
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
I Made a Shift ****...Look
I made a shift **** this month and thought I would get some opinions from you guys. My interior is black/charcoal with a silver/black steering wheel which just came in and I have a silver headunit. On a scale from 1-10 what do you guys think? It still needs to be polished I may get some different rings for it but you guys can get the idea. Heres my car http://www.cardomain.com/ride/756169 and a picture of the **** below.
Engine: Lg4 305
It ways a little over a pound, same weight in grams as TWM's .44 ****. Is around 2 1/2 tall and feels right. I tapped it to m16x1.5 and its stepped a little wider than that before the threads.
Edit: meant to add another photo but forgot and now it wont allow me to.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
looks good. I can't wait until I take the machine shop class in junior year engineering and i can use the machine shop anytime... Than i could make sick things like that for my car
Engine: Lg4 305
Ya all you need is a piece of metal, I started with a old trailer ball because I could still the threads of it in the lathe and then tap it which was the hardest part because we didnt have a tap that large.
1 Post
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
is that flange on the bottom for the boot to slip over? if the boot is going to be below the **** (like stock) i would also recomend cutting it down.
OVERALL A+ JOB!!!!
OVERALL A+ JOB!!!!
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
getting there but it looks like a trailer ball still.
i would cut the base down and taper it more at the the bottom side that would remove the trailer ball look. nice job.
Car: 91 formula
Transmission: t5
just curious as to what its made out of.... just some food for thought, if its not aluminum and you dont put someing on it, it will rust....
Engine: Lg4 305
By the way it was from a trailer hitch but it was perfect because when using a lathe you need something to stick into the jaws that had to be very straight and true otherwise it will wobble and even the slightest wobble will cause the lines to get very crooked especially in areas such as the slots for the o-rings. So I stuck it in, flatten the sides of the ball, straightened the taper underneith it, and straighten the rounded cap at the bottom which I may end up cutting off. Hardest part was getting the writing and numbers off the top of the ball sinces its a dead on angle. Then went and pulled some very small o-rings into the grooves, cut the threads off the hitch, drilled it, drilled a larger neck at the bottom, and then tapped it. All in all it was suprisingly easy and was able to finish it after school after a couple days but I got lazy.
Engine: Lg4 305
Just to let you guys know I finally got my license today. Bought the car almost two years ago and basically finished it 4 months ago. Now I get to show it and the shift **** off considering the only bad thing I have heard about the third gen is the interior. Just got the stereo in which was almost free 75% off, steering wheel which I still have to pay within 2 weeks, and the shift ****.
morrow
01-13-2024 12:29 PM
TheTraut88
09-07-2015 05:22 PM
