A little mod
Car: 1990 RS coupe
Engine: TBI 305.
A little mod
I got a hold of some expanded mettle a few months ago and had intended to fab a grill for my car since I had ripped out the dry rotted piece of black plastic that once occupied the space
Well tonight a couple hammers a jigsaw a pair of kleins and I got around to it
It cost me absolutely nothing so that counts for something and I think it looks alright
(Please no stupid posts saying I should have bought one and so on because Im not going to spend that much on a peice of plastic)
Heres the pictures
Heres the pictures
Car: 1990 RS coupe
Engine: TBI 305.
It took me about 30 minutes to do
I plan to get a black plate with a chevy emblem on it for the middle area
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
how did you mount that in there ive been thinking about doing that to mine but behind the grille and i havent got back there to see how to mount it.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
looks ok but it think i would of painted it silver to let it stand out more
Car: 1990 RS coupe
Engine: TBI 305.
Originally posted by theSteve
sorry man, i don't dig it. looks cheap to me.
Originally posted by Jim85IROC
You trying to keep the chickens from getting out of your engine bay?
I have it fitted in place in the picture
I used some electrical wire (Where you cant see it) to secure it
I might change the color to an aluminum color later
On a side note I had no grill but I had the material to make this one and after paying $313 for tires and still having to replace an idler arm and struts I dont have the money to buy expensive materials
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
Originally posted by Aredross
That would be because it is cheap.........but do tell why you think it looks cheap
It looks cheap (to me) because your 'mod' is a clear indication that you opted for a budget fix instead of spending the dough on the appropriate fixture.
It looks very out of place, in my opinion. But what do I know... I don't even have a grille
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Your car has braces
It doesnt look that bad, but i think it might look better behind the center section
Idea: A
Execution: C
Good luck
(BTW: Im not flaming you)
Idea: A
Execution: C
Good luck
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
behind the license plate area would definitely look better, even if you do put another plate over the center area i think having it recessed further would look better.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the mesh needs to be finer and going the opposite direction (horizontal instead of vertical)
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, good call nova...
anyone care to do a photoshop to see what that would look like?
I think it's pretty slick. An emblem in the center will make it pop more.
Car: 1990 RS coupe
Engine: TBI 305.
Thanks for the input
Changing the direction was something I already wanted to do
The piece I had was already cut off and I lacked the appropriate tool to cut another strip so I went ahead and did that one(I might make another one late like that)
I will think about messing with it later
Heck it still looks better than the stock louver peice
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
yep yep, cool idea, i know ur on a budget soo the first thing u can do to make it look a lil better is take some of these guys advise and put the mesh behind the the center thingy, the next step would be to get some finer mesh and then give it a nice glossy paint job and it should look really cool, I know what a pain meshing (lol "meshing") can be I have a turbo hood and cutting and placing all that mesh for the isnt fun.
Car: 1990 RS coupe
Engine: TBI 305.
yeah Ill see about that
My avater is that that..........for some reason I thought it would be cool to make it the message telling me to change it
Im not sure why
Im not sure why
