Replacing doors
Old 09-29-2005 | 09:10 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Replacing doors
How much is involved in replacing doors? Mine are rotted and I have a set off a Camaro I parted out that are MINT. How hard is the wiring, how hard is it to get everything bolted up? Any tips or suggestions? Thanks,
-Chris
Old 09-29-2005 | 09:15 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
You can do it in about 20 minutes. It is really really easy. I have to take mine on and off to check fitment while installing my lambo doors. 6 bolts hold them on 4 from the outside and 2 from the inside. Thats it. depending on power options, then there are more or less things to unplug. But like i said a sec ago, it is all just plugs. Pretty impossible to mess up. Def not an intimidating job. Good luck.
Old 09-29-2005 | 09:16 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I pulled mine from my 89 and it was like 7 bolts I think. REALLY easy. The problem is I didn't know what to do with the wiring, I had to cut the wires. You'll have to disconnect them from the motors and solenoids (if power) and feed them through the holes. They are HEAVY doors too so watch out. Steve bought mine, maybe he can tell you about wiring them up.
Old 09-29-2005 | 09:24 AM
Engine: LS3
Just unplug the motors. If you can't or don't feel like it.....then slash the wires and splice them back in later to the car. No biggie.
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
86IROC112
04-09-2016 10:20 PM
BlackTopKing
08-19-2015 12:13 PM
Quick Reply: Replacing doors
