color sanding!!!
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
color sanding!!!
i just painted my car and i need to get the gloss out of it because the paint looks dull. badly enough that i have to try my best to fix it or re spray it. but how would i color sand it what do i use?? any experts out here?
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
i would sand the paint with 2000-3000 grit wet sand paper then use 3M polish and buffing wheel. just dont go to far and sand through the clear or it will have to be re-cleared.
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
The clear should be glossy before wetsand/buff (when properly sprayed). Sounds like you did not spray the coats of clear thick enough. Wetsand for buff as previosly mentioned grit paper. If you are going to re-spray with color/clear, use 600-800 grit.
Pac J
05-17-2020 10:44 AM
gixxer92
05-18-2017 11:20 AM
Dragonsys
09-25-2015 03:51 PM
