stragne interior floor panels
Old 09-25-2005 | 05:18 PM
Steve51186's Avatar
Car: 1984 Trans-Am
Transmission: auto
I striped out the interior of my 84 trans am to clean up any surface rust while the car is currently off the road today, While scraping 21 year old glue off the floor pans i noticed in front of each of the four seats there is a small remoavble panel maybe 2" by 3". WHen you take it off you can see the ground outside. No wires are coming through and its defiinitly not just a cheap patch job, because they are very uniform in size. What are they there for?
Old 09-25-2005 | 05:51 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Factory drain holes.
https://www.thirdgen.org/techbb2/sho...hreadid=200214
Originally posted by Trickster
If you pull the carpet out of the passenger compartment you will find four (4) more of those little doors located at the low points in the front and rear seat. They were used as drain points when the vehicles were dipped at manufacture and then sealed and used as attach points to hold the carpet in place when it was installed.
The Trickster!!!!!!!!!!!!!!!!!!
Old 09-25-2005 | 09:22 PM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
If I remember correctly, someone once said that those holes may also have been used in the manufacturing of the vehicles - that they may have been mounted on jigs from those holes. I have no idea if this is true or not tho....
Vintageracer
01-10-2020 05:33 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
3.8TransAM
09-03-2015 06:38 PM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: stragne interior floor panels
