NAME THESE MYSTORY CONNECTORS! and other thing
Old 09-17-2005 | 06:56 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i got have been woundering what these connectors are for and if they should be hooked to something. also this thing under my carpet that the carpet is cut away to reveal
http://x1.putfile.com/9/25918445156-thumb.jpg
HOW DO YOU PLACE PICS in this thread that a nother web site is hosting?
Old 09-17-2005 | 08:21 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
use the IMG built into the reply to link the images. Also those pictures show me nothing one is super huge and the other is really small I can't tell anything.
Old 09-18-2005 | 08:40 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Both photos show the same thing, looks like the cut in the carpet in the hatch well? This thread says the bracket underneath the carpet is to hook a flat tire to, since a normal size tire won't fit in the spare tire well. I don't know why GM would bother with that, the times I had a flat my tire just barely fit in the well, so I really didn't think it needed to be held down.
https://www.thirdgen.org/techbb2/sho...hreadid=185541
waiting for photos of the mystery connectors....
Old 09-18-2005 | 03:50 PM
Car: 1997 S10
Thanks for all the help heres the resized pistures
Old 09-18-2005 | 04:54 PM
bru333's Avatar
Car: 1987 Camaro SC
Not sure about 1 (foglights maybe?) and 2 (?).
Number 3 is your ALDL connector for the ECU.
Old 09-18-2005 | 05:36 PM
Car: 1997 S10
yea thats what i thought #1 was also and i have a fog light switch. but i did not think Rally Soprts came with fog lights boy this has me really woundering about my car where you able to get fog lights on a 91 RS?
Old 09-18-2005 | 06:08 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i believe most cars had the same wiring just whether or not the option was used in a specific car. Like most cars have the harness for power seats yet only some actually have power seats.
Old 09-18-2005 | 06:54 PM
Car: 1997 S10
oh i see but i wounder wht i have the fog light switch. does anyone know what the #2 mystory coonnector is for?
Old 09-19-2005 | 12:49 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
From that angle, it looks kind of like the headlight/dimmer switch connector, but I'm not really sure. It doesn't look like it has enough wires going to it. Do you have any better pictures of it?
Old 09-19-2005 | 09:15 AM
Car: 1997 S10
i will try to get some in a couple days
Old 09-20-2005 | 09:35 PM
Car: 1997 S10
ok well i got some more pics of the #2 mystory connector here you go
Old 09-22-2005 | 09:51 AM
Car: 1997 S10
anyone? i can get more better pics again if needed
Old 09-22-2005 | 02:58 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Does your car make that ding or buzzing sound if your lights are on or keys in the ignition?
do your hazards work?
Old 09-22-2005 | 05:16 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
number 1 is hte plug for the foglight switch itself, and number 2 looks like the plug into the column for the high low beams.. do you have high beems ?
Old 09-22-2005 | 06:03 PM
Car: 1997 S10
yes my car buzzes when my key is in the ignition and when the headlights are on.
i do have high beens BUT only when i use the rod to turn them on not with the lever i guess the switch it selfe moved back over the years.
Old 09-22-2005 | 06:47 PM
Car: 91 formula
Transmission: t5
then it might be for hte relay for the fogs, what are all the colors on the wire
Old 09-22-2005 | 07:01 PM
Car: 1997 S10
the colors are green,yellow,blue and brown.
Old 09-23-2005 | 03:04 PM
Car: 91 formula
Transmission: t5
im gonna stick with its for the relay for the fog lights... even though the brown should be a purple wire..., is there another connecter under teh dash that has the same colors as that and looks like that only the brown wire is a purple wire ?
Old 09-23-2005 | 04:14 PM
Car: 1997 S10
well i just wen back out and took a look and i thought there was another one up there but i could not find it. what is supposed to plug into that thing?
Old 09-23-2005 | 05:07 PM
bru333's Avatar
Car: 1987 Camaro SC
Originally posted by 91rsowner4life
It sure looks like a relay would plug into it.
Attached Thumbnails NAME THESE MYSTORY CONNECTORS! and other thing-ry115.jpg
Old 09-23-2005 | 06:16 PM
Car: 1997 S10
ok thanks any one know where it would be located at?
Old 09-24-2005 | 07:23 AM
Car: 91 formula
Transmission: t5
i assume your car doesnt have fog lights, since well you have no switch, i can clearly see that you have no fuse in your fuse box for them, and you obviously dont have the relay, so you really dont need it, unless you added factory fogs to the car.
Old 09-24-2005 | 10:36 AM
Car: 1997 S10
um... i do have the factory fog light switch its under the headlight switch. thats the thing i do not understand why i have all this stuff and i do not have fog lights.
Old 09-24-2005 | 07:17 PM
Car: 91 formula
Transmission: t5
then whats plugged into it ?
Ghettobird52
07-05-2024 11:18 PM
Bob88GTA
08-18-2015 03:31 PM
86White_T/A305
08-17-2015 12:16 AM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: NAME THESE MYSTORY CONNECTORS! and other thing
