Dashpad rattle?
Car: 87 Camaro Z28
Engine: LG4, CCC
Dashpad rattle?
I just took the 'maro on a little road trip, and thankfully had the chance to open it up a bit on the freeway. Damn it's fun to drive. However, at speed, maybe around 70-80 mph my dashpad and the center vents that attach to it shake like all hell! It's really annoying and I'm worried it'll damage the dashpad over time. Does this happen to anyone else, and how can I fix it? Happy labor day! Cheers!
1 Post
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Check the screws or take it off to see if the thin layer of foam is gone or something. My dash pad didn't shake (when i had my 83 that is). Maybe you have some vents lose that go to the dashpad.
Car: 87 Camaro Z28
Engine: LG4, CCC
I know there are two of the four screws towards the front of the car missing, but it's the side closest to you that shakes. Also, it's not just the pad that shakes, but the whole thing it's screwed into. Kinda mystifying me.
1 Post
Car: '94 Z28
Engine: LT1 350
Does it rattle and just make a noise or is it rattling like you can see it? If it's just noise take stuff apart and see if something is loose or broken, but if the whole thing shakes then i'd start tightening every bolt i could find.
Car: 87 Camaro Z28
Engine: LG4, CCC
Um, yeah, the word rattle is kind of a misnomer. The whole pad shakes visibly, in a very obvious way. What bolts are there other than the ones that hold the dashpad to the rest of the dash?
Drove me crazy too. Put a little brace on mine down to the the cig. lighter pod. Really don't notice it and the dash is 50% steadier at least. I'll take a picture of it if you want.
Car: Pair of 92 Z28s
hah...i hate these dash pads...my trick which pretty much did it
folded a rag a few times stuck it under the pad and tighted down all the screws....worked like a charm
Ive had to ghetto rig so many plastic interior pieces with carpet or some type of padding to stop the squeaks its annoying as hell
Car: 1987 Trans Am
You could glue subbox carpet or felt behind any panel that rattles; this works well on the backs of license plates too, esp on cars with lots of stereo equipment. The first time I rode in Redraif's car, I was amazed that it didn't squeak or rattle; that is a large part of why it doesn't. There is subbox carpet glued between the dash and dashpad, on the backs of all the plastic panels...pretty much everywhere it could rattle. Sounds crazy, but it worked, and didn't add a whole lot of weight, either.
Car: '89 RS Vert
Engine: LO3
Mine does the rattling thing too, right at 75mph it gets really bad to the point that it shakes the radio and makes a CD skip. I'm pretty sure it's my rotors that need turning so you probably have the same problem... either that or our tires need balancing.
I have the same problem with the dashpad shaking or vibrating at speeds close to 80mph. I balanced my wheels last week and put in all new steering parts over the weekend and after my alingment i still have the same problem. I am gonna look into the driveshaft thing myself and if not that maybe make sure my wheelbearings are okay.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Hey it's a third gen everything rattles mine does the same thing I dont want to tighten it down anymore though, because I don't want it to crack
sub-frame connectors. Now that i have them, my dash pad does not move. Balanced tires are a must also. Ages ago i couldnt have answered this question.
mw66nova -
mw66nova -
use sticky foam tape under dahs pad perimeter and around vents and such
buy it at local builders or hardware store or evne at wal mart
bye bye all noises of all kinds
use it in other places too
cheap and simple and effective
interior rattles and such drive me nutty, i cant stand any noises inside at all, i hear any squeaking or anything and i will hunt it down and kill it quick
A driveshaft vibration is usually a high speed buzzing type, through the whole car. A rear wheel imbalance sometimes is felt in the seats, the passenger seatback especially will shake. The front wheels will shake the steering wheel and dash area. One thing to look for is the wheel weights only on the inside of the wheel on the fronts. This makes the wheels look better and works ok at normal speeds, at 60 or so everything is fine, but at 80 you'll get vibration from the side to side imbalance. If the wheels are balanced one side only, try a new balance with the weights on both sides as needed. Also look for the shop with a Hunter wheel balancer, seems to be a notch above the Coates and others. And there are millions of tires out there that have runout, not as round as they should be.
