lining up hatch
Car: 88 firebird
Engine: 2.8
Transmission: 5 speed
lining up hatch
I been doing some work on my 88 firebird. I put in a new pull down motor for the back hatch..
The hatch isnt lining up to good and was woundering if anyone knows how I can line it up better?
Thanks for any help!
Car: 88 firebird
Engine: 2.8
Originally posted by bru333
The search button is my friend!
Do you think the search button will be my friend too??
Thanks bru!
The second picture looks as if the hatch pull-down unit is adjusted too low. Did you attempt to correct the alignment problem by lowering it? If so, you'll soon have the clear plastic part (called the motor housing) break apart. You'll need to raise the hatch pull-down unit and adjust it until it pulls the hatch down and you hear the "CLICK" of the reversing switch, but hear no strain whatsoever in the motor.
Lon
Lon
Car: 88 firebird
Engine: 2.8
Lon
Lon
I didnt do anything to the pull-down unit, Just installed it..
The first pic(passager side) its level, And as you can see in the sec pic(the driverside) is lower..I'm not hearing no "click" either..
Not sure how I ajust the pull down motor to make both sides level..
Thanks lonsal!
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
pull down
that pull down is the biggest p.os. they made. i cant figure why they made such a big bulky assembly and my dads caddy has a small motor that is much more reliable
mine stopped working in 91 so i took it off and put a 84 firebird plain latch on works great
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
So what did you do to re-align that so well? THe steps in the linked post?
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Randomtask2
09-10-2015 08:37 AM
