rear seat back removal?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I've got my interior stripped down to nothing left, but the back of the rear seat is the only thing left.
How do I get that out???
I can see what looks like 2 T-30 torx screws holding it on it's pivot, but there is a metal panel about 1" from the head of the screws, such that there is no way I can get my bit on it, plus the ratchet...
Is there a trick to this?
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Well there is a bolt underneath outside of the rear seat that needs to be removed in order to allow the seat to slide off the pivot. I used a swivel head ratchet and a 3" extension and it came off pretty easily. Just feel around underneath the seat until you feel the bolt. You may have to push the fabric out of the way.
Car: 1982 Trans-Am
Indeed! Thank you! I just used a 13mm wrench... Don't know how I missed that....
Thanks!
Thanks!
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
wait, where the heck is that, i always used a torx screw driver bit with a box end wrench on it does anyone have a picture of this bolt?!?
Car: 1982 Trans-Am
sorry, camera is away for a week here...
if you fold your rear seat half way down, then look under the pivot area, for a bolt... you'll only see the threads, and the nut, you can get the nut off and you're good to go...
(unless this is another one of those 1982 only things...)
Axle/Gears: n/a
i think i understand. it's on the outer edge (facing extirior of car, not hump) portion of the seat, what the torx head bolt threads into? i'll take a look and report back.
Car: 1982 Trans-Am
yep, you've got the location right. The bolt is pointing downwards, so the nut is threaded "upwards".... you'll find it...
