T-tops 82-92 all the same?
1 Post
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I have a 92 firebird with the plexi-glass t-tops. I found a very nice set of glass t-tops for a 85 firebird. Will they fit on my 92? Is or was there a recall on the plexi-glass t-tops? Thx.
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
from what i can figure, the tops are all the same size, there would be no benifit to GM changing the design, other than the latches, some have pins others have hooks as well as locks or no locks.
if your car has the pin style lach you can change it to the hook style or vice-versa.
but as far as glass or plexi, i had glass and changed them to plexi, theres no difference in the dimensions or shape.
Vintageracer
09-24-2017 12:34 PM
no green
01-09-2016 09:22 PM
Thirdgen89GTA
11-26-2015 11:04 PM
