82-92 Door differences. Help!
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
I just installed a 92 door in my 83 camaro. I t fits right except after I bolted the gfx back on there is a gap between the bottom
of the door gfx and the cars gfx. These peices are not adjustable so my question is are the doors slightly different? What the hell do I do now? Everyone who sells used parts lumps 82-92 door together like there all the same. Classic Industries on the other hand only sells door skins for 85-92 camaros. Was there a change from the 82-84 to the 85-92 doors?
Thx in advance.
Thx in advance.
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
(LT1guy)
The doors aren't any different, but its possible the holes are not quite in the right place. Try opening up the holes a little bit with a drill or a dremel to gain some more adjustment.
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
Originally posted by redraif
(LT1guy)
(LT1guy)
The holes for the 85-92 are higher due to the thicker ground f/x.
At least this is the case for Firebirds.
-bill
Car: 1983 Z28
Thanks guys, very helpfull. I'll have to compare the gfx mounting holes when I get home.
Car: 1983 Z28
Originally posted by 87CIZ
with camaro's 82-84, 85-90, 91-92 had different mounting holes for the gfx.
1Aauto
Sponsored Vendors
01-09-2018 02:19 PM
1Aauto
Sponsored Vendors
02-08-2017 03:09 PM
