Hood not right?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Functioning hood scoop on 84 z28?
Well i have an 84 Z28, according to the FAQ's this was the last year for the functional scoops on the hood. But one problem, mine arent functional... whats up with that??
I'm not a Camaro guy...but I believe They produced BOTH for a while.
Yours probably is not.
Car: 2012 Corvette Grand Sport 'vert
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
The 83's with the Cross-Fire Injection were the last ones with the functional SMC ("sheet-molded compound" - fiberglass) hood.
My 83 was an LG4, so my hood wasn't functional either, but it was at least made from the lighter SMC, as opposed to the 84's steel hood.
None of the 82-84 carbureted Z28s had a functional hood....
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
ok thanks, On that note the FAQ's should be fixed as they say up to '84 Z28 models are functional.
Anyone have pics of the functional hoods?? are they just the same thing just with the holes cut in them?? if thats the case ill break out the dremel
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Well i was bored last night so i busted out the dremel and started cutting
I have a rough cut of the holes, ill finish them off probably tonight and put some screen in there. Already i have noticed a 55*F drop in intake temperature
Previous intake temp 185*F now it is 130*F. I didnt think it would be so effective at dropping the under hood temps. Also just realised how close the top of my air cleaner is to the hood, theirs less than 1/4".
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
just to let you know they discontinued the functional hood scoops because they had problems of rain entering the engine i belive. just my
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
