Paint Respirators
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Paint Respirators
What would brands/styles would you guys recommend? Im not going to spend the money on a fresh air ($350-$1000) for one job, because that would seriously tip the scales to having a pro do it... So, i guess the word is CHEAP...
Thanx guys
Thanx guys
Car: 88 sc. convert
Engine: 305 TBI
Transmission: Formerly 700-Now T5
Go to your local paint shop and get a 3M "disposable". They are like $15 or so. Well worth it for one or two jobs.
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
yep go with the 3m. i think hokpaint.com has em for like 16.00 non disposiable just change the filters when needed. oh and bag the filters when your not using the mask they will last longer that way.
jeff
jeff
1 Post
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I just bag the whole respirator when Im not using mine. Same deal though. 3M is good.
Car: 1987 Iroc-Z
Engine: 355
sweet, cause i was seeing disposables for upwards of $155 and such... i'll definately get those... when i can finally get this goin..
thanx guys
thanx guys
Car: '89 Firebird Formula
Engine: 305 TBI
good questoin what kinda protection do they offer though? i keep reading they dont do crap about isocyonates, and have yet to read anything that says they do
i got the 3m disposable one, the paint shop guy recommended it to me, just curious
havent used it yet
i just have a good feeling my booth isnt going to contain much fresh air once i get going so i want to make sure im not going to keel over halfway thru :P
havent used it yet
1 Post
Well, I used one of those for about a year. In school. And they help up fine, and Im sure the school would not give us ones that would go bad.
Rabbitt, def put up pics of your car when you are done. I always like yours and I was wondering if you were going to paint it. BTW, if you dont mind me asking, what color are you thinking?
Car: 1987 Iroc-Z
Engine: 355
hehe, not in the thinking stage anymore.. black! with blueberry pearl in the clear... all HOK products.. My fiance and I bought a house last year, and we have been having problem after problem... so i keep getting pushed back.. and with school starting on the 6th, i may be screwed out of getting done for quite awhile...
Hey Jeff, how long do HOK products sit on the shelf?
Car: 88 sc. convert
Engine: 305 TBI
The 3M ones have a charcoal filter, that's what is supposed to remove the isocyonates. They are not really disposable, but for $16, why buy $20 elements for it?? Plus you get a whole new clean mask every so often.
You need positive pressure, ie; fresh air.
Car: 1987 Iroc-Z
Engine: 355
Originally posted by KEVIN G.
NOTHING...Absolutely nothing will FILTER out Isocyonates!!!!
Jeff, is this the one you were talking about?
1 Post
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Iso's will not kill you on one job. Your body will, if contaminated, gradually build a resistance to the iso's. Liken it to filling your beer mug... as it fills up and there's nowhere else for it to go...it spills. That's what happens in your body, it fills up with the anti-bodies and your resistance is gone. But hey, look at it this way, in 20 years you'll make a good vibrator for your wife, as you lay twitchin' in bed, cause all the coating is stripped from your nerves.
The important thing to remember is... Iso's do not ONLY exist in the clearcoat, but the primer and sealer as well.
And protection is not only in the form of respirators, they will attack you at ANY mucus membrane. Your eyes, for instance. You need a shoot suit, nitrile gloves, goggles, and a mask of good quality, designed for paint protection. Look for the NIOSH stamp.
1 Post
Engine: 305 tpi LB9
hahah im gonna be a vibrator.. thats a good one. isos are in any catalized paint. so not the bases mostly clears and candies and primer.
yes rabbitt thats the mask i used, paint will last a long time as long as it does not freeze. and its closed tight.
i have a fresh air system and i hate it can;t see crap with it on its a hobby air.. is there any better hood designs out there?
jeff
jeff
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
-J
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
