clutch pedal
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
clutch pedal
where can i find a replacement rubber one. mine rotted and fell off????
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Hawks thirdgen has the rubber pedal covers. BTW James C are those aluminum pedal covers from MBA products?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: clutch pedal
Motormite p/n: 20721 (*edit- this is the brake pedal pad number- see below for correction)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
MBA products is closed down now. not sure if they are going to open back up.
That motormite part number, is that the exact same fit as the stock one? I tried findind one in the Help section a few years ago and the only one they had that was close to the size was too big, so I had to go with the aluminum bolt on pedals which are nice if you wear anything but dress shoes with hard soles.
Engine: TPI 305/ v6
Good you asked though... I rechecked and apparently Motormite has thier crap bass ackwards... (clutch pad listed under brake & vice-versa)
the clutch pad is p/n: 20717.. slightly smaller than the brake pad...
