broke a piece when dropped steering column... WHAT IS IT?
Car: 1998 Trans Am WS6
Transmission: M6
I broke that piece that has a cable type of thing connected to the brake pedal when i dropped my stering column... What is it and what does it do and will it affect my performance at all?
-Scott
-Scott
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If it's an electrical wire to brake pedal, either brake light switch, cruise control switch or tcc switch. You'll have to be more specific or provide a photo.
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Re: broke a piece when dropped steering column... WHAT IS IT?
-Scott
-Scott
Re: Re: broke a piece when dropped steering column... WHAT IS IT?
Originally posted by Crovax
if you dont know what you are doing and you're breaking stuff under there then maybe you should stop before you mess something up that you cant fix. youve got a chiltons manual , use it before you come on here and ask dumb questions.
sk8runeg, do you have a picture or a better description of what it is you broke? You should have a rod that goes to the brake booster, and either one or two electrical switches. One for cruise control and one for brake lights. They all will effect the car to varying degrees.
Transmission: M6
I found out that it is the cruise control mechanism that is notorious for breaking when the steering column is dropped. Thanks for the help guys.
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Re: Re: Re: broke a piece when dropped steering column... WHAT IS IT?
Originally posted by onebinky
Why the negative disposition? That sounds like a legitimate question to me.
Scaahty! ya ****in idiot! shoulda mentioned the vac. line in the first place, and that woulda made it so much clearer! stupid JB :P haha
1992 Trans Am
05-10-2023 07:19 PM
