Crooked Steering Column
1 Post
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
My steering column is off to the right. There is more of a gap on the left side where it passes through the gauge cluster. Any ideas how I fix this?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There are two nuts under the dash that hold the column to the dash support. Loosen the nuts, slide the column to whatever side has the larger gap, and tighten the nuts again. You have to remove the hush panel to get at the nuts first, though.
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
sjorgens
10-01-2015 07:54 PM
