door hinge rivets
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
door hinge rivets
does anyone know where i can get the rivets that go on the top door hinge? i wasnt sure if they are a special type since the hinge pivets or if i can just use any rivet i can fit in there.. my t/a has bolts in place of the rivets on the top hinges and they are sagging.. i am going to get the car painted soon so i wanted to fix it right..
Car: '89 Firebird Formula
Engine: 305 TBI
say huh?
well they are supposed to be specially made peices, its not something your going to find in the hardware department
theres just bolts in there right now? interesting idea heh
TDS (http://www.top-downsolutions.com/) sells a kit to repair the hinges, go look im pretty sure thats what you asking for
Axle/Gears: 327
hinge
yeah the top has a bolt w/ a lock nut where the rivet goes the bottom long pin is still oe and in good shape im going to check the link now.. thanks
Hotrodboba400
12-10-2019 07:07 PM
