Camaro console in a FB
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
just wondering if any camaro console will fit in a 88 formula 350?
if so what would be needed?
i would plan on replacing the shifter
currently has power windows
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Direct bolt in. If the camaro console came from one with power windows then you're all set, no need to cut it to mount switches.
1 Post
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
My console (Camaro) has the HVAC controls molded into it
My brothers (Firebird) doesn't
I don't know exactly what that's going to entail for you, just letting you know.
Car: '91 TA vert
Engine: turboLSx
He meant that the radio pod/HVAC mounting area was molded into the conter console. I can't say I've heard of anyone wanting to ditch the rounded firebird console for a maro one though.
Car: 1989 Firebird Formula 350
Transmission: 700
Please let me know if you decide to go with the Camaro center console because I have a 1989 Firbird Formula 350. I'm interested to see if it fits. I installed a B&M Mega Shifter (universal) because the console ones wern't made for Formulas. My center console & Radio/AC console are in bad shape.
Thanks,
CWH
Thanks,
CWH
Engine: TPI
i'm deciding on what to do
i may make my own console out of wood and carpet it
the way the firebird console bubbles out on the side near the shifter plate annoys me to death
also her console lid is broken too
hence the reaon i was thinking about using the camaro one, wasn't sure if the whole radio pod assy and all would have to change
then i can also easily mount the console shifters
i'd like to see photos of your shifter that you put in, the universal one.
Car: 1990 Formula
Axle/Gears: 3:73 Posi
A guy i used to work with put a 84 Camaro console into a 87 Firebird. looked fine. and he said it was pretty much a straight foward swap
1992 Trans Am
05-10-2023 07:19 PM
