Power windows help asap
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
What color goes where on the power window switches I have Blue, Black, Brown, Pink on driver’s side and Blue, Black, Tan, Pink passenger side? And I have only 1 connecter with ABCD on it so does it matter witch side I put the connecter? Please respond soon my windows are in the down position.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Re: Power windows help asap
The switches are the same, use 'em on either side...
driver side
A-black
B-brown
C-dark blue
D-pink/white
pass side
A-black
B-tan
C-light blue
D-pink
Car: 84 Z28
Engine: GMPP 350 HO
K thanks it worked I just need to know what color goes where like you listed and if the actual connecter on both sides is labeled the same as far as ABCD are the same I only have 1 connecter I did not have the factory switches originally now I do
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
09-13-2015 09:07 PM
