Installing a BCM from a later F-Body
Car: 89 Black IROC-Z
Transmission: TH-700r4
Has anyone tried installing a BCM from a 4th gen to get the benefits of theater lighting, accessories running until you open the door, etc...?
Im thinking about trying it but i dont know if the BCM will run without the other modules serial data.
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
its impossible to install a BCM into a 3rd gen, if you like the whole BCM thing, go buy a 4th gen and take every wire from it and install it into a 3rd gen, then, maybe it'll work
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
www.the12volt.com
They have alot of info on relays that can do somethings such as "accesories on until the door opens".
Originally posted by firebirdjosh
www.the12volt.com
www.the12volt.com
jd
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
it is possible to put the 4th gen bcm into the thirdgen.... but like jimp2001 said above you will need to rewire alot to do so... im doing it in mine for the same effects you are looking at as well as the factory keyless entry, but i also have gone to a 4th gen interior as well so i have already changed pretty much all the wireing to 4th gen... but again it is definatly possible.. isnt everything??? lol... just takes some work
Street Lethal
08-13-2015 08:28 PM
