eew!! Dog breath!!!
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
eew!! Dog breath!!!
My interior kinda smells a bit funky...either like
1. Old interior
2. Dog breath
3. Dog breath
4. Dog breath
5. Dog breath
I'm not sure....but I think it may be 2 - 5?
So, does anyone know how to gwet rid of stinky smells inside of an interior aside from airing it out?
1. Old interior
2. Dog breath
3. Dog breath
4. Dog breath
5. Dog breath
Engine: 3.4 / 5.0
Oh yes, I shall try the febreeze! I forgot about that. And that coffe bean thing? Hmm...I'll try that too! I wouldn't mind the smell of fresh brewed coffee in my car
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
FIRST.... make sure the carpets and seats are dry and theres no mildew growning in the car, if there is, the smell will just come back.
They make a febreeze for cars now... I can't tell the difference, but it got the dog breath out of my car, lol
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
you can also take some standard charcoal brickuetts <sp> like for grilling. stick em in a sock or nylon and leave it in the car it will absorb all the odors. works great for closets and garage basement ect...give it a try.
jeff
jeff
Car: 1991 Camaro Z28
Coffee grounds, not beans. Its an old used car dealer trick. Empty a whole can of cheap coffee grounds into your car. It'll absorb the smell in a few days and if there's no mildew growing in your car it won't come back.
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Fabric sheets that you use in the laundry work to. When I used to work at RentWay we used them in the refirgerators to get the nasties out. They really work. I put one sheet under the seat in each one of my cars.
Car: 1987 GTA
Transmission: 4L60e
if you can track the smell to some doggy drool spots, then your best bet would be to spray it down with wd-40. Give it time to dry and evaporate, and you won't have any problem smelling either wd40 or dogy breath again.
My dad used this method on his work boots and was aloud to bring them back inside the house again
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
go 2 a gm dealership and buy stuff called odor eliminator.we have it at our dealership and i used it in my vents and carpet its great! its used for getting rid of smells anyware in ur car. u spray it into the cowl and let the fan run for like 10 mins for the vents. and on the upholstery u can follow the instructions or spray it around then vacumme it out. good stuff
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Steam clean the interior. I have one of those bissel carpet cleaning things with an small attachment on a hose with a spinning brush that works well in the car.
You can't cover up an odor expectiong to get rid of it. It might mask it with feebreze or the like for a while but thats it. You need to remove the source of the smell to get rid of it.
A good cleaning. Then after it has dried you can try sprinkling baking soda all over the place, leaving it for a while then vacuuming it up.
Car: 89 Formula 350
Engine: a Big one
Transmission: I dont keep them long.
Not that i would think you would have anyreason to worry.
but if you use alot of freebreez in your car if you ever get pulled over. You could possible be the subject of a car search.
A lot of the youth around here use it to cover up the smell of weed and other substances so dont just drench you car in it... They may think your hidding somthing... hehe..
JUST A FYI. and good luck with the smell.
