strongest double-sided tape?
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
anyone know some really tough double-sided tape? only stuff I have been able to find is from joann fabrics and it really isnt that tough....looking for some that will remain 'sticky' even though some warm temps
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
hit a home depot and go look for contractors double sided tape, i have a roll, this stuff is impossible to get of
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
yea i have used the green and white tape and it sucks big time. go with the red and white label.
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
I think the 3M tape is rated for different weights. Just get the outside type tape for the highest weight they have and I guarnatee it will hold anything in place!
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
get the red one like previously mentioned. thats the stuff thats used on auto ventshade stuff. trust me when i say it sticks. almost broke a window visor in half when i went to go pull up a piece that i mis-aligned. the tape is unbelievable strong.
I checked menards, and home depot today, but no luck. All I saw was the green and white which is rated 2lbs per 120mm (something like that)....not nearly strong enough. Scotch brand had some rated at 5lbs....but looked more like 'indoor' tape.....Im gonna keep searching for that red and white
1 Post
Car: 92 Formula
Engine: 5.7 L
We sell it at Radioshack. It's only a couple bucks. That stuff does wonders. A customer once used it to put a clip on there phone. and when they tried to take it off it actually borke the plastic shell of the phone before it would let go.
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Red 3M double sided tape is the best. I've probably used a good 5000 feet of that stuff in my lifetime, and never seen it fall off when its put on properly.
Car: 1991 Z28
Transmission: 4L60 automatic
Any auto store should have it,even Walmart has the 3M tape.If it's for the door molding Walmart has a 1/2" wide roll in a black(I think) package in their auto section and in their house paint section.The roll itself has a red backing on it that you peel off...I think that they have 3M in one other width.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I would suggest going to an autobody supply shop...or car quest. We get 3M products that once it's stuck...it's stuck. I can probably get a part number for you tomorrow
BADNBLK
Convertibles
65
02-10-2016 03:36 PM
roysatikas
09-22-2015 08:15 PM
