Ram Air Hoods
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
Ram Air Hoods
I have a carborated 305, is the air box that comes with a ram air hood used for carbed engines or just fuel injected. Also will the hood make a difference without the air box.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
airbox is only for an FI setup, but you could use it for a carb setup if you really wanted too.
Ram Air hood will give you more clearance as well as giving you some nice cool air if the nostrils are opened in the front and the back of the hood is opened up as well, and if you are running an open element air cleaner.
Car: 89 GTA
Engine: 350 TPI L98
Originally posted by Tripper511
Whats an open element <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=31&k=air%20cleaner" onmouseover="window.status='air cleaner'; return true;" onmouseout="window.status=''; return true;">air cleaner</a>?
Whats an open element air cleaner?
My old 86 T/A before the 2 FI Swaps
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
08-24-2015 06:52 AM
