anyone done racing seats? common in!!
1 Post
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
hey,
im buying some racing seats, but i need to know what i need to get them to work in my iroc..
anyone done this yet?
thanks
dysturbed
thanks
dysturbed
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
many have, depends on brand, they can be a direct bolt in or needing a little modifacation.
One thing tho, is dont just drille holes in the floor pan, floor pans are like 16ga steel and will bent in the event of an accident. Try your best to remove the stock support bar, and reweld it where it can be used most. If at the vewry least modify your brackets to bolt to the stock mounts. Maybe make an extension plate....
1 Post
Axle/Gears: 3.45
thanks
iroc2nv
Engine: 355 TPI
take them in? like pay a shop that charges $60 an hour to install seats you could do in 3 hours, and you'll prolly end up with a bill for 10 hours of work for their soda breaks. Please dont do that. Man if you lived closer i'd do it for you. gosh, try something on your own, its not too hard.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
depends on the brand and options. if you buy corbeau do not buy their brackets for 82-92 as they are too tall, if you have to buy them buy their 93-02 f-body brackets as they are lower.
if you buy recaro they don't make brackets, you'll need to outsource, do a search here and you'll find the website. look up wedge engineering, theirs are right on with height however depending on your interior options you may have to modify slightly.
just about any seat will fit, the brackets are the tricky part.
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
I got APC seats. I wanted to keep my power seats and DID NOT want to drill new holes in my floor boreds. So i got some 4inch wide by 2-3 feet long bars of steel and drilled new holes in them and used them. Only took about 4 hours.
Car: 1991 RS
Engine: 7.4 454
Transmission: Th 400 man valve stage 3
APC are the ones i got also, install was a pita, but look ok and the coin was right... so in they went. i modded the stock brackets
wich dont allow the seat to adjust. they are locked in one place.
its fine for me, i am the only one who drives the car.
1 Post
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
I put a nice set of Sparco Torino seats. Iused full manual seattracks from an 86 Trans Am. All I had to do was drill 2 new holes in the track to bolt it to the seat, otherwise it was a breeeze!
install time - 20MINS!
Car: 1991 RS
Engine: 7.4 454
Wow. those are nice... Gonna have to save my pennies for an upgrade..
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i did a set of APC seats. as far as the brackets go i got some flat stock and welded a box frame and bolted the stock brackets to it. my friend has a monte with the same seats and he went with wedge enginerring brackets. they are really nice brackets but i didnt want to spend the money on some thing like that were the money could be spent elsewhere.
Car: 1988 Camaro
iroc2nv.... I put a set in my car a few mo. back. Very easy to do.
There's no need for you to have a shop do it for you.. Your car, your mod, you should do the work. Not only will you know nothing was messed up, but you'll have the pride of knowing you done it yourself. Plus you'll have more cash in your pocket.
Here's the info I posted on here about my install. All the need to know stuff, info on how I did it, plus pics of how I did it, and parts list.
Take a look
https://www.thirdgen.org/techbb2/sho...hreadid=283339
Also you may want to look at this.. It was a topic on race seats that I replied to alot, even posted a pic of when I 1st started the brackets for mine
https://www.thirdgen.org/techbb2/sho...hreadid=277118
Take a look
finally finished the recaros over the weekend, the brackets from wedge engineering would have been right on in stud location but i had the cage so i had to move the passenger 2" and the driver only required opening the holes a bit. the front of the seats sit a bit higher then i'd like but still lower then my corbeaus at their lowest point. the rears once adjusted fit perfectly, with things set as low as possible i'm 1.5" lower then my lowest angle with corbeau which is very nice.
took roughly 1 hour to get it all together. the brackets were $150 from wedge. same as the $150 from corbeau.
good luck.
good luck.
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
i made brakets to bolt my recaro's in out of 1/8 inch aluminum. my brakets for both driver and passenger seats weigh 15 ounces. the seats however, are heavy. i plan on buying a set of fixed-back seats soon, as the drivers side power/heated recaro weighs 35lbs with the braket.
84 TA NV
09-06-2015 08:02 PM
