t-top to hardtop
Car: 86 IROC
Transmission: WC T5
t-top to hardtop
Can it be done? I have done searches and could not find anything. I hope that isn't trying to tell me something. I just want to get rid of the t-tops and go with a hard top. Ideas?
I wanted to do the opposite of you, go from hardtop to t-top and to do this is VERY expensive, roughly $2,000 in a body shop if they will do it. the biggest stickler for a body shop is liability in case of a rollover. just better off finding a hardtop.
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
You want a hardtop? Everyone I ever talk to wants t-tops. They are awesome in summer.
Why do you want a hardtop? Doesn't a cage give you the needed strength?
Car: 86 IROC
Transmission: WC T5
The crash happened 7 miles into the 90 mile run. He did walk away with minor bumps and bruises. The video showes he shifted way to soon when trying to slow the car down after a blowout.
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
shouldnt be hard and it would be easier if you left the cage in the car some how, that would actually save money for you because they have to weld in supports when chopping the top because it will bend in as soon as that top is off.
ive considerd it many times...but just said id rather buy another f body for that
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Reverse this...
http://www.markscustomkits.com/t-top-conversions.htm
... and ta-daa... hardtop car you'll have.
Engine: 5.7tpi 350,
Originally posted by subsonic9
I should call them and see if My car could be a donor and get the hard top free, Or at least cheaper. Good looking out.
how did that work out for you did you call them
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Hardtops for life.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
my new GTA is a hard top. my old bird was a ttop. i'll never look back.
hardtops for life.
hardtops for life.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
T-tops are great, even when (not if) they leak.
But seriously, I've seen some roof graphs, be it t-top to hardtop or vice versa. Get a top section, cut the 4 pillars, and weld it up. It's not too hard if you think you're up to do it in the first place.
Car: 86 IROC
Transmission: WC T5
I checked it out but not sure about connecting at the pillars. The thought of that(Part or end of the pillar) in my face in a crash seems worse than the glass part. So for now I stick with the T-top drip in my left leg. And that is with new weather strips. I hate that seam there. I have thought about welding a section of the hard top in place of the T-top section. My body guy thinks I'm nuts. Oh well he is not far from wrong. lol
Thirdgen89GTA
11-27-2015 12:04 AM
