'82 Trans Am Fender Question
My mother backed into my cherry '82 Trans Am. I need to find a replacement for the drivers side fender and door skin. I'm having a difficult time finding it. I'm told that '83 and '84 fenders will be a perfect interchange by some and others tell me they will have holes that will need to be filled in due to the "ground effects" addied in '83 and '84. Does anyone have the difinitive answer? Does anyone know where I can get an '82 replacement? Thanks
Car: 1984 Trans Am
Engine: GMPP 350 V8
82-84 T/A fenders are the same.
SOME 83 and 84 T/A's had W62 ground effects. If you get a fender from a car that had GFX, then yes, you will have to fill the holes. Otherwise you should be fine.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
all the years will fit yes, only earlier years had the vent and early gfx
i think the vents carried through 85 or 86
thats crap that a cherry one gets damaged
its how it always happens though
the nice oens get hurt and the beaters keep on going
good luck
good luck
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
'82-90 Trans Am fenders will interchange. You may need to weld up and redrill ground effects holes depending on what year car you get the fenders from. '82 T/A and '83-84 non-W62 Aero Package T/A fenders will be a direct no hassle swap.
Only '91-92 Trans Am and' 87-92 GTA didn't have the air extractor vents.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
