Door Poppers
Door Poppers
I'm gonna be shaving my door handles when I get my car redone and repainted in the next few weeks....i was just wondering if anybody had a good kit to suggest or something that I could order....I'm in the blind kind of on this, and don't exactly know which kit I need....so if somebody has shaved door handles, with a kit that works real nicely...could you just share some info so I know which kit to buy...thanks...
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
autoloc.com or the vpa kit from summitracing will do just fine....get solenoids that are less than 45lbs or you may run into problems that I did (too much pull, I'd recommend 30-35lb)
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Do yourself a favor and put locktight on all the bolts related to the kit. They'll knock themselves loose after time.
okay will do...which kit to buy now? that VPA kit i didn't see anythign in the 30-40 lb range, and the autoloc is real expensive....i would like to spend around 150 or so...
i am getting mine from Godfather customs... http://www.godfathercustoms.com/cata...s&page=2&uni=1
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Electric life makes a kit with alarm for 200 bux, thats what i got, never had a problem with it.
