Door panels?
Old 06-14-2005 | 02:07 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Door panels?
Does anyone know what type of glue (or it it something else?) is supposed to be used to reattach the water deflector (plastic piece) to the door again? It's the piece underneath the door panel and is stuck to the door.....the original glue doesn't stick very well seeing that I had to remove the deflector. Thanks
Old 06-14-2005 | 10:29 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Axle/Gears: 9 Bolt 2.77
I didn't even know it was held on with glue. I thought it had clips to hold it.
Old 06-14-2005 | 01:39 PM
Untamed's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Any type of water proof cement or silicone will work. I replaced my water deflectors and used a clear apoxy that was created to repair tent and camper tops - bonding fabric to metal. So far they've worked fine. I know this because two months after installation I removed the old door panels to swap them for black ones and saw neither water stains (dried droplettes on the plastic) nor rust.
Old 06-14-2005 | 04:45 PM
1989karr's Avatar
Engine: 3.4 / 5.0
hey thanks for the reply guys, I'll definetley do/use that!
Old 06-14-2005 | 04:47 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
I'm an idiot
I thought you were talking about the black rubber piece at the bottom of the door...Mine was just held on with some black sealant. Haven't had a problem so far.
Hotrodboba400
12-10-2019 07:07 PM
RyanJB
05-07-2016 06:23 PM
tglennon11
09-23-2015 05:30 PM
NiG
09-07-2015 11:25 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Door panels?
