Hatch pull down motors
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
my hatch motors release function is working but thats about it, iam wondering if i need a new motor or is it something i can fix, how can i tell.
Axle/Gears: 3.45, 3.27, 3.27
First, the hatch pull-down unit and the hatch solenoid release are on separate circuits and separate fuses. Check out the tech article I wrote. Pull off the rear hatch surround trim panel and check that you have +12v at the red with white stripe wire that is plugged into the blue wire of the hatch pull-down unit. If no power, then check the fuse for teh hatch pull-down unit. On Camaro it is the #3 fuse (15 amp) located in the first row, third column of the fuse panel, on Firebird it is a separate inline fuse next to the fuse panel.
Lon Salgren
Top-Down Solutions
Lon Salgren
Top-Down Solutions
