Door hinge or pins (how should I know?)
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
hi,
I got sagging doors.....but I don't know can I replace the door pins only to fix it, they are pretty bad, two side of the door are not flat even after closed, the door hinge is very expensive in Taiwan, what should I do?
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
I put in new pins and for the hinges , both top and bottem and it still didnt fix the problem. So before you buy, make sure the pins will do the job.
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
Check the metal bushings, I bet thats your problem. I can send to some bushings if you pay for shipping, I got something like 500 of them.
Engine: 2.8
Transmission: auto
hi Yossarian14,
which part is bushings? my English is not good enough....sorry, I have no problem to send the cost thru Paypal if the problem can be fix
regards,
Joe
regards,
Joe
Engine: Lg4 305
Sorry I didnt see that you lived Taiwan but if you look it shouldnt be hard to find a replacement especiall on this site. I had sagging door and it was because you have a bushing that eventually get worn down just from use especially with the big heavy camaro doors and this allows the pins in the hinge to jiggle. Sorry if I am not being much help. I may have some pictures if you want them.
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Realign the lower hinge where it meets the body. Its a few bolts and that can make a huge difference, especially if its still sagging after new pins are installed.
Engine: 2.8
Transmission: auto
thank you Yossarian14, I think the problem I have is find out what parts should I replace, maybe the door hinges and others, my friend told me the door latches should be replace too..........almost everything to lock the door......
Hi firebirdjosh,
how to realign the lower hinge? disassemble it and .......put it back ? what should I noted ?
Joe
Hi firebirdjosh,
Joe
1 Post
Car: 86 T/A
Engine: HSR 355
Remove the plastic kick panel (inside by your feet). Loosen the bolts that attach to the door. Jack the door up slightly higher than it rests. Tighten bolts.
Its that easy.
Its that easy.
Hotrodboba400
12-10-2019 07:07 PM
wigmobile
09-17-2015 03:38 PM
gta892000
09-16-2015 12:37 AM
