What's this piece called?
Car: 83 Z28
Engine: Mild 383 Stroker
Transmission: B&M TH400 with shift kit
Axle/Gears: 3.73 Limited Slip
ok i'm wondering what this piece is called... its the little plastic strip that is on the bottom of the nose piece of the car.... mine is about 3 inches thick and i know they have some that are longer that look like they come on the later 3rd gens... i'd like to get a new piece but i don't know what its called... i noticed that it has little screws holding it all the way around and i want to get a thicker one becuase it makes the nose of the car look like it sits lower and mine is broken anyways.... anyone got any info that'll help?
You mean the front lower air deflector??
It direcs air flow from the road up into the radiator... not sure if this is what you mean.
Also I don't think it's as crucial on Z's but they are a must have for every Bird owner.
1 Post
Car: 85 Z28
Engine: LG4 modified
I think you're talking about the Ground FX (GFX), sometimes called the front skirt also. The 1991/1992 Camaros had more prominent GFX on the front and sides, with imitation air ducting on them.
Car: 1991 Trans-Am
Engine: 350 TPI (SLP mods from factory)
Transmission: 700 R4 (built with 2500 stall)
Axle/Gears: 3.23 Disc Posi
I believe it is called Front Valence Panel. CHeck it out and see.
Car: 83 Z28
hmmm well then.... i wonder what it is all i know is they look better with a longer one cuz its closer to the ground... so i'm wondering where i could buy one...
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
