is this normal
Car: 1983 Z28
Transmission: TH350
is this normal
i intalled new weather stripin that runs down and around the door and from what i can tell i did it write. but when i shut the door it would not shut with the normal effort, i have to slam it hard, are u suppost to work it in or something or did i do something wrong? should this be happening??
thanks in advance
thanks in advance
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Is it SoffSeal by chance ?
Anytime you have a pretty good sealed cabin, you'll be closing the door against air/cabin pressure if it cannot escape... unless you have soffseal.. then you just shutting the door against hard-___ w'seal.
just my opinoin though...
Linson
10-01-2015 09:50 PM
