Removing 1992 firebird nose question. . .
Hello, Everyone :
I am seeking information on . . .
" HOW TO REMOVE A 1992 FIREBIRD FRONT NOSE BUMPER ".
I have heard there are 4 main bolts on each side of the nose, but need to know the EXACT way to remove it, without removing screws / bolts that really do not need to be removed.
If there is anyone out here that honestly knows how to accomplish this project, PLEASE post.
PICS or DIAGRAMS would also help !!!
Thanks you so very much, everyone . . .
D WAITE
D WAITE
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If you only want to take the plastic cover off there are 4 bolts along each side of the nose that go into the fender, these can be a pain with the hadlights in. I recommend taking them out. Undernesth the car should be 4 tabs held into the bumper by the push in rataining pins if you will, you need to pull the center pin then you can remove the whole thing. Then there are maybe 8 screws that hold retaining bars (think thats what the parts catalog calls them) on. These sandwich the lip over the front support piece. After the retaining pieces are removed then you need to lift the lip up and the whole thing should come off. Sorry I dont have any pictures, i never took pictures any of the times I have done it.
