Old Brackets With New Seats?
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
Hey i just got some new APC super racing seats from jcwhitney and was wondering can i still use the power seat on the drivers side with my new seat?
Car: 1985 Trans Am
Engine: LB9
The brackets on those seats do not line up with factory holes. You need to take the seat rails off of your stock seats, remove the brackets on the APC seats, and mount the stock brackets. However, the mounting holes do not line up with the tracks from our cars. You will need to drill new holes in the APC seats where their brackets were attached, and make the mounting holes in the stock thirdgen brackets significantly wider.
I'm assuming your power seat tracks mount up the same as the manual seat tracks, which they probably do.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i made a box frame for mine using flat stock and them bolted them to the seat. came out good and you cant see the box frame either
IROCZDAVE (88-L98)
09-02-2015 09:49 AM
