these wheels
these wheels
is there any way on G0d's great earth to make these wheels fit on my 89 iroc camaro?
http://www.5zigenusa.com/
click on wheels and go to Fno1r-c. these wheels look sick in person ( especially the rears) but camaro is not one of the applications, but i was wondering if there was any modification i can do to make them fit...thanks for the answers guys. sorry if this is a dumb question.
Car: Formula
Engine: LO3 5.0l TBI V8
Transmission: WC T-5
You'd have to get an adapter that would change it from a Ford bolt pattern to a GM Pattern. then it should work.
any idea as to where i can get a kit like this?
and what do you think of the wheels? yea or nay...keep in mind that i will prolly get the silver ones. Thank guys.
Car: 88 GTA, 00 SS
Engine: L98, LS1
Transmission: 700R4, T56
imo these cars look better with a thicker spoke than that, but they are nice rims and would be different. good luck
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
go with the zr1 rims. they almost look the same and at least you know that they fit with adapters
call skulte in connecticut 860-674-1985 and see what he says about it. i would still go with the zr1's though
http://skulte.com
thank you for the replies guys...they have really helped me. I have one more question..does anyone know the stock bolt circle size on an 04 mustang?
talk to andris and he should know
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Order the set listed for these FC3S R, S14, Z32, 350Z, V35 Rear
Thats if your going to go 17x9 all round, they are 35MM offset, then tell Skulte that you want a set of adapters that are 1.1" thick with 5.75 bolt circle for the holes and 5.5" for the studs.
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Mustangs are 5 on 4.5. Or did you mean the size hole where the stud goes through. I may have misunderstood the ?.
drptop70ss
10-04-2015 09:44 PM
